Still two things which need improvements
Postby lujo » Fri May 13, 2011 10:06 pm
After standby issues there are still two things which need a fix.
- Diseqc 1.2 which is not reliably working.
- Faster change to HD channels. At this moment (see my previously posts) 5 seconds is needed to lock to HD channels. I am using TVSource and TVSource is sending signal that it is HD channel so driver should understand that, but it don't.
I hope those issues will be fixed soon.
That is the reason that I want to ask: Does TBS team recognise this as issue which need to be fixed and can we expect that this will be fixed within the short term?
lujo
Re: Still two things which need improvements
Postby pjm » Sat May 14, 2011 9:49 am
lujo Wrote:After standby issues there are still two things which need a fix.
- Faster change to HD channels. At this moment (see my previously posts) 5 seconds is needed to lock to HD channels. I am using TVSource and TVSource is sending signal that it is HD channel so driver should understand that, but it don't.?
AND ALSO
for Windows 7 64 bit (at least)
- 22khz switching doesn't work
- TSReaderSources - causes registry corruption and fails to "Retune to mux carrying this service" (when selected from from SDT table entry)
- TSReaderSources - does not accept parameters/options passed to it by TSReader
- The TPS IP tool fails on startup with "CBDAGraph::ConnectPins() - Could not connect pins together. Error was:"
pjm
Postby israb » Sun May 15, 2011 6:55 pm
And also: fast device release upon DVBViewer crash.
israb
Postby lujo » Sun May 22, 2011 6:24 pm
Is TBS working on those issues and how long will it take to solve this?
lujo
Postby lujo » Mon May 30, 2011 7:31 am
Can I conclude that nobody is trying to solve those issues? Please respond, because if this is true I am going to try card from another brand.
lujo
Postby Nenya » Mon May 30, 2011 11:40 pm
More and more sporadic reaction of engineers (actually only one) weakens confidence on their willingness to work... :( Steven, please respond!
Nenya
Postby steven » Tue May 31, 2011 4:05 pm
we really appreciate all the users who report problems/issues here in the forum, we are doing our best to solve the problems.
However,sometimes we don't have so much time for replying the questions in the forum, if it's urgent, please kindly send us email, our support email address is:
support@tbsdtv.com
Thank you for your understanding!
Postby steven » Tue May 31, 2011 4:07 pm
Would mind tell me which soft you are use?
about this luchy had explained why.
Standby Resume OK with Driver 2.0.0.7
Postby A1880 » Mon Jun 27, 2011 4:58 am
Just to confirm:
My TBS 6921 properly resumes work after Standby with Win7 driver 2.0.0.7
(working on Windows XP SP3 and TBS Viewer).
With driver 2.0.0.2 I still had the Standby problem.
Greetings
A1880
My PC:
Intel Core i7-2600 @3.40GHz, 8 Cores, 8 GByte RAM, 64 Bit Windows 7 Home Premium SP1, Dell XPS 8300
A1880
