Diseqc 1.2 switching problem or something else?
Postby lujo » Fri Apr 15, 2011 3:55 am
-TBS 6921
- Moteck-1200A
When I switch from SD channel 19,2E to HD channel 23,5E I get with TVSource "Sorry, cannot display this channel either because there is a technical problem or no TV signal.".
If I switch between two SD channels on different satellites there is no problem. It happens only (so seems) when switched from SD to HD on different satellite.
Does this have to do with the driver of TBS 6921 that tries couple times to lock SD channel and when it cannot lock it only then try to lock HD channel. And maybe TVSource is not waiting so long....?
If I try DVBViewer it works (SD -- HD different satellites) but it takes long time, about 16 seconds. My motor turns between 19,2E to 23,5E in 2 seconds or less.
This is the message from TVSource log: "Error. CTVSProgramSource::SelectProgram. PAT scanning has timed out"
Please help, because TVSource is not helping with this problem.
Old log:
Error log:
2011-Feb-09 18:43:45: Info. CBroker::PlayErrorTS. sink-source pair was established, source: 3C19F447-4CFD-46b5-9D03-7C3521C37661, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:44:05: Info. CBroker::FindSource. sink-source pair was established, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:44:19: Info. CBroker::FindSource. sink-source pair was established, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:44:26: Error. CTVSProgramSource::SelectProgram. PAT scanning has timed out
2011-Feb-09 18:44:26: Error. CTVSBridgeControl::ChangeChannel. Program source has failed to start the programn streaming
2011-Feb-09 18:44:26: Error. CBroker::SwitchToChannel. ...Switching to channel {4A0420EE-C24D-4FD5-B7F5-AD745F2FDD62}:11973000:1:1078:28679 failed, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:44:26: Error. CBroker::SwitchToChannel. sink-source pair has been removed, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:44:26: Info. CBroker::PlayErrorTS. sink-source pair was established, source: 3C19F447-4CFD-46b5-9D03-7C3521C37661, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:45:11: Info. CBroker::FindSource. sink-source pair was established, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:45:20: Info. CBroker::FindSource. sink-source pair was established, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:45:26: Error. CTVSProgramSource::SelectProgram. PAT scanning has timed out
2011-Feb-09 18:45:26: Error. CTVSBridgeControl::ChangeChannel. Program source has failed to start the programn streaming
2011-Feb-09 18:45:26: Error. CBroker::SwitchToChannel. ...Switching to channel {4A0420EE-C24D-4FD5-B7F5-AD745F2FDD62}:11973000:1:1078:28679 failed, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:45:26: Error. CBroker::SwitchToChannel. sink-source pair has been removed, source: D2AB52BB-6F85-407F-8AC1-9F2CABE83EB8, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
2011-Feb-09 18:45:26: Info. CBroker::PlayErrorTS. sink-source pair was established, source: 3C19F447-4CFD-46b5-9D03-7C3521C37661, sink: 85C11CC8-7772-4443-AB5B-DA0F0FD4F689
lujo
Re: Diseqc 1.2 switching problem or something else?
Postby lujo » Sun Apr 17, 2011 1:23 am
Please see my last post in another thread for more information:
https://shop.tbsdtv.com/forum/viewtopic.php?f=23&t=283&start=10#p1845
lujo
