problem with scanning hd with dvbviewer
Postby bfc123 » Mon Mar 21, 2011 5:03 pm
I am having troubles with scanning some hd channels with dvbviewer.
eg NatGeo HD at sky italia:
while it should have been: 11785/H/29900 2/3 video pid:2514 service pid:14236
Everything is wrong while all sd channels are scanned fine.
any help?
bfc123
Re: problem with scanning hd with dvbviewer
Postby jw300 » Mon Mar 21, 2011 10:04 pm
http://en.kingofsat.net/find.php?question=NationalGeo+HD&Submit=Zap
This search shows two entries. The one you picked up may be a promo slide. You may not have scanned the other yet, or else the entry needs updating. Did you tick the "DVB-S2" box?
jw300
Postby bfc123 » Tue Mar 22, 2011 12:27 am
Yep, I tried ticking DVB-S2 box, with no luck.
This is happening with all DVB-S2 channels on skyitalia. One user from dvb viewer forum send me a channelist scanned with another dvb card and with that channellist the dvb-s2 channels are working fine.
Also with another dvb soft I can scan the S2 channels at their "normal" frequences.
bfc123
Postby bfc123 » Wed Mar 23, 2011 3:31 pm
Scanning with transedit solved my problem.
bfc123
