Any End-user reviews of the blind-scan feature of this card?
Postby guacharaca » Tue Feb 22, 2011 10:32 pm
Has any end-users successfully used the blindscan feature of this card? Did it blindscan a DVB-S2 signal? I have had a tbs6980 for almost a year now and certainly miss the ability to blindscan DVB-S2.
guacharaca
Re: Any End-user reviews of the blind-scan feature of this c
Postby cody » Wed Feb 23, 2011 5:18 am
with current driver version there are some issues with blind-scan performance, for which you can read in the forum. other than that it does blind-scan for DVB-S2 as well as of course DVB-S.
Postby vasvi » Wed Jun 22, 2011 2:07 am
In my case it works OK and finds all active transponders from 36e sat (S and S2).
But I have another problem with this card:
https://shop.tbsdtv.com/forum/viewtopic.php?f=23&t=366
I think it is not worth to buy this card now as it has a lot of glitches.
vasvi
Postby wilberforce » Thu Jun 30, 2011 10:09 pm
I never had any success with the blind scan feature with this card . It does not see transponders I know are there, and it lists transponders which are not there. I bought the card for this feature and was hoping there might be some mew software or drivers posted to make it work but at the moment i think the card is a wast of money!
wilberforce
