Tbs2605 BT.709 Problem
TBS2605 HDMI Video encoder not only supports 2 channels 4K or 5 channels H.265 encoding, but also supports multiprotocol output. Each channel supports HTTP/HLS/RTMP(RTMPS)/RTSP/UDP protocols outputting simultaneously. TBS2650 is equipped with 4 x TBS2605 encoding boards in 1U chaasis.
TBS2605/TBS2650 has been upgraded to integrate with NewTek's royalty-free NDI®|HX technology, converts the HDMI input signals into full-bandwidth NDI streams seperately, enabling users to effortlessly connect HDMI-equipped sources to NDI-enabled media networks, devices and applications.
Postby wordbox99 » Sat Nov 06, 2021 2:47 am
Hello
Why is this device not outputting Bt.709, why is there no software update? I request your help in this matter.
App version:1.0.0 build 20200823_660
SDK version:1.0.0 build 20200821_16281
Sys version:1.0.0 build 20200823
wordbox99
Re: Tbs2605 BT.709 Problem
Postby daowei » Fri Jan 28, 2022 3:12 pm
It supports, it's because the metadata of the "color space" is not packaged yet, do not worry.
Postby wordbox99 » Wed Feb 09, 2022 7:09 am
When will you send the new software, you do not support this machine, please help. Submit the new software.
wordbox99
Return to TBS2605 /TBS650 multi-channel 4K / 1080P 60hz HDMI Video Encoder
