50 fps Framerate is variable
TBS2603SE is a professional HDMI video encoder, which supports 1 channel HDMI stream of H.264/H.265 encoding output and the AAC, Mp3 audio format, and it can work with NDI®|HX compatible systems.
Postby Chris18391344 » Thu Jun 25, 2020 5:24 pm
we have few customers connected to TBS-2603 SE with the same Problem.
We set a Framerate from 50 fps, but many Videotool shows a VARIABLE Framerate as result. The result is, many Videotools make errors. As Example. TMPGENC Smart Renderer function.
This Tool required a fixed (constant) frame rate, not a variable.
Whats wrong ?
Chris18391344
Re: 50 fps Framerate is variable
Postby daowei » Sun Jun 28, 2020 4:10 pm
Hi Chris18391344,
The tool indicates a correct parameter.
For the real-time encode, "frame rate mode" it is variable indeed. Frame rate is correct as you set,and 50fps.
Postby Chris18391344 » Wed Jul 01, 2020 1:36 pm
Hello daowei,
that's correct, but we need a Constant Frame Rate, not a Variable Frame Rate.
Chris18391344
Return to TBS2603se Professional HD H.265/H.264 HDMI Video Encoder
