TBS2604 Firmware
TBS2604 Firmware
Postby oawan » Thu Oct 10, 2019 3:33 am
I accidentaly updraded my TBS2604 to 1.1.96 (which was meant for the TBS2603). Now nothing works, no surprise, but I can still get into the GUI. I'm trying to upgrade the firmware to 1.0.17 but I get to 100% and it doesn't give me the message that it has been upgraded. Any thoughts on how I can get the right firmware on it?
oawan
Re: TBS2604 Firmware
Postby daowei » Sat Oct 12, 2019 10:13 am
oawan Wrote:I accidentaly updraded my TBS2604 to 1.1.96 (which was meant for the TBS2603). Now nothing works, no surprise, but I can still get into the GUI. I'm trying to upgrade the firmware to 1.0.17 but I get to 100% and it doesn't give me the message that it has been upgraded. Any thoughts on how I can get the right firmware on it?
Ok, understand.
Each Encoder has its private firmware, can't mix. Please setup a remote check, we'll fix it. Or you can contact with me in Skype:
daowei23lily163.com
Or write e-mail to me directly when you're availabel:
daowei@tbsdtv.com
Postby oawan » Wed Oct 16, 2019 12:52 pm
This is resolved. If this ever happens to you, you will need a local instance of Linux (or Ubuntu 16.04) to replace a file on the encoder. It's a bit involved so it's best to setup a TeamViewer session so TBS support can do this for you.
oawan
Return to TBS2604 / TBS2640 4K UHD HD H.265 & H.264 HDMI Video Encoder
