TBS2604 Onvif Discovery Port
Postby oawan » Thu Oct 10, 2019 3:23 am
What is the Onvif discovery port for the TBS2604?
oawan
Re: TBS2604 Onvif Discovery Port
Postby daowei » Sat Oct 12, 2019 10:00 am
oawan Wrote:What is the Onvif discovery port for the TBS2604?
For Encoder TBS2604(4K Encoder), need to upgdate to v1.0.19 first, we add ONVIF to support in version:
https://www.tbsiptv.com/download/tbs260 ... 1.0.19.zip
unpack the zip package first and when upload "update.tar.bz2" to upgrade.
The discovery port is "8001".
Postby oawan » Wed Oct 16, 2019 12:56 pm
This is resolved with the new firmware. However the onvif client failed to pull the main and 2nd encoding URLs. The most you can do is set the time and the network config (Ip settings). For example, Synology Surveillance Station discovered the devise but failed to set the encoding URL.
oawan
Postby poddingue » Tue Nov 19, 2019 12:38 am
What about the TBS2605? Does it work with Onvif? What does it provide?
Thanks.
poddingue
Postby daowei » Tue Nov 19, 2019 10:19 am
poddingue Wrote:What about the TBS2605? Does it work with Onvif? What does it provide?
Thanks.
Yes, TBS2605 supports ONVIF, and the ONVIF will be a newer version, it's v1.0.
TBS2604 is using a older ONVIF version, maybe this is the problem. Whast's your ONVIF usage? to NVR?
or to some software like "Milestone"?
Postby poddingue » Thu Nov 21, 2019 3:05 am
Thanks.
In fact, I don't know yet. I have discovered only recently what onVIF is, and see that I could benefit of its use (like semi automatic recording of the video streams onto hard disk drive, just in case something bad happens).
I don't know yet if I would use some kind of giant onVIF console, onVIF HDD recorders, onVIF screen monitoring...
But anyway, I'm almost sure that it could help me in some way.
poddingue
Return to TBS2604 / TBS2640 4K UHD HD H.265 & H.264 HDMI Video Encoder
