Screen stopped working on the TBS2605
Postby poddingue » Mon Sep 30, 2019 10:30 pm
This morning, I rebooted the TBS2605 and got that on screen:
Since then, even after rebooting, it is still looking this way.
What can I do?
Thanks.
poddingue
Re: Screen stopped working on the TBS2605
Postby daowei » Sat Oct 12, 2019 10:09 am
poddingue Wrote:This morning, I rebooted the TBS2605 and got that on screen:
What can I do?
Thanks.
In this case, can you login webUI? and Encoder function still ok?
Noramlly, if only something wrong with LCD display, will not affect the Encoder function, becasue LCD only for display some IP, encode status, and etc.
I think probably the problem is related to the connection of the PCB board to LCD side is loose, please remove the power, open the case, and reconenct the connection cable(a 4-pin and white cable).
Postby poddingue » Sun Oct 13, 2019 12:10 am
The encoding is still doing fine, and the web UI too, but as I am using DHCP (I have to), it's not handy to have to guess the IP.
If I open the box, will it void the warranty?
Thanks.
poddingue
Postby daowei » Mon Oct 14, 2019 10:06 am
poddingue Wrote:The encoding is still doing fine, and the web UI too, but as I am using DHCP (I have to), it's not handy to have to guess the IP.
Thanks.
Yes, void the warranty.
Don't worry, i think the problem is the conenction cable beceoms loose, just open the case and reconnect it. Please try.
And if you don't know which IP Encoder got in DHCP mode, you can reset it. After "reset", IP will back to the default "192.168.1.217". And maybe static
IP will be better, i recommend you the "Static" way to get IP.
Return to TBS2604 / TBS2640 4K UHD HD H.265 & H.264 HDMI Video Encoder
