TBS 6209 Octa-Tuner - Record 2+ simultaniously
Postby thatfellow » Wed May 26, 2021 7:01 pm
I currently have 1x TBS 6209 Octa-Tuner
According to the specification:
This tuner is capable of receiving 8 channels simultaneously.
The PVR I am using is NextPVR Version: 5.1.1.210329
When a second recording clashes with a current recording, I get this error on the recording:
[Failed: No errors, but no data delivered. This is usually because the device failed to lock a signal.]
Here is the NextPVR log of the failed tuner 01, this test was done when tuner 00 was in use.
[...startup]
2021-05-26 10:24:00.728 [DEBUG][1] Args...
2021-05-26 10:24:00.729 [DEBUG][1] -listen:52370
2021-05-26 10:24:00.730 [DEBUG][1] -type:DVB-T
2021-05-26 10:24:00.730 [DEBUG][1] -device:TBS 6209 Tuner 1
2021-05-26 10:24:00.730 [DEBUG][1] -instance:1
2021-05-26 10:24:00.730 [DEBUG][1] -parent:5052
2021-05-26 10:24:00.730 [DEBUG][1] Starting web server on port: 52370
2021-05-26 10:24:00.749 [DEBUG][1] Found parent process: NextPVRServer
2021-05-26 10:24:01.244 [INFO][4] Got POST request: /stream/start?slipseconds=1200&target=D%3A%5CNextPVR%5CVideos%5CPeppa%20Pig%5CPeppa%20Pig_20210526_10251030.ts
2021-05-26 10:24:01.247 [DEBUG][4] Starting Stream: D:\NextPVR\Videos\Peppa Pig\Peppa Pig_20210526_10251030.ts
2021-05-26 10:24:01.248 [DEBUG][4] SlipSeconds: 1200
2021-05-26 10:24:01.248 [DEBUG][4] Tuning:
<tuning>
  <type>DVB-T</type>
  <locator>
    <frequency>578000</frequency>
    <bandwidth>8</bandwidth>
  </locator>
  <service_id>1102</service_id>
  <tsid>1001</tsid>
  <onid>8564</onid>
  <service_type>25</service_type>
  <provider>RTÉNL</provider>
</tuning>
2021-05-26 10:24:01.291 [DEBUG][4] StartStream(): D:\NextPVR\Videos\Peppa Pig\Peppa Pig_20210526_10251030.ts
2021-05-26 10:24:01.340 [DEBUG][4] Using tuner: TBS 6209 Tuner 1 (1)
2021-05-26 10:24:01.341 [DEBUG][4] About to connect...
2021-05-26 10:24:01.341 [DEBUG][4] has network provider
2021-05-26 10:24:01.341 [DEBUG][4] has tuner
2021-05-26 10:24:01.363 [INFO][4]             [161bb869-07cf-4d13-a4b1bc64e67209be]-00030004-00000000
2021-05-26 10:24:01.364 [DEBUG][4] About to auto detect capture filter...
2021-05-26 10:24:01.365 [INFO][4] Need match: [161bb869-07cf-4d13-a4b1bc64e67209be]-00030004-00000000
2021-05-26 10:24:01.367 [DEBUG][4] dw1=00030004 vs 00030004
2021-05-26 10:24:01.369 [DEBUG][4] Got capture filter: 'TBS 6209 Capture 1'
2021-05-26 10:24:01.369 [INFO][4] medium:    [161bb869-07cf-4d13-a4b1bc64e67209be]-00030004-00000000
2021-05-26 10:24:01.369 [DEBUG][4] Added capture filter
2021-05-26 10:24:01.371 [DEBUG][4] Connected Tuner to Capture
2021-05-26 10:24:01.410 [DEBUG][4] Graph filter list:
2021-05-26 10:24:01.411 [DEBUG][4] - MPEG-2 Sections and Tables
2021-05-26 10:24:01.411 [DEBUG][4] - BDA MPEG2 Transport Information Filter
2021-05-26 10:24:01.412 [DEBUG][4] - MPEG-2 Demultiplexer
2021-05-26 10:24:01.412 [DEBUG][4] - NPVR TS Mon
2021-05-26 10:24:01.412 [DEBUG][4] - Capture
2021-05-26 10:24:01.412 [DEBUG][4] - Tuner
2021-05-26 10:24:01.412 [DEBUG][4] - Network Provider
2021-05-26 10:24:01.413 [DEBUG][4] Graph Connections
2021-05-26 10:24:01.414 [DEBUG][4]   Filter [48392ac]  'MPEG-2 Sections and Tables'
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [483984c]  'In' [I]  Connected to [4830084]
2021-05-26 10:24:01.414 [DEBUG][4]   Filter [4834634]  'BDA MPEG2 Transport Information Filter'
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [4834f94]  'IB Input' [I]  Connected to [482ff04]
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [482169c]  'OOB Input' [I]
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [48354b4]  'iTV Out' [O]
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [4829c8c]  'SBE OUT' [O]
2021-05-26 10:24:01.414 [DEBUG][4]   Filter [4829fe4]  'MPEG-2 Demultiplexer'
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [e0d1bc]  'MPEG-2 Stream' [I]  Connected to [9a79f4]
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [482ff04]  '001' [O]  Connected to [4834f94]
2021-05-26 10:24:01.414 [DEBUG][4]       Pin [4830084]  '002' [O]  Connected to [483984c]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830204]  '003' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830384]  '004' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830504]  '005' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830684]  '006' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [48308ac]  '007' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830a2c]  '008' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830bac]  '009' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830d2c]  '010' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4830eac]  '011' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [483102c]  '012' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [48318ec]  '013' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4831bfc]  '014' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [48323a4]  '015' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4831d84]  '016' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4831f0c]  '017' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4831a74]  '018' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [483221c]  '019' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [48315dc]  '020' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4832094]  '021' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [4831764]  '022' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [48333ac]  '023' [O]
2021-05-26 10:24:01.415 [DEBUG][4]       Pin [48336bc]  '024' [O]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [483309c]  '025' [O]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [48339cc]  '026' [O]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [4833fec]  '027' [O]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [4833844]  '028' [O]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [483276c]  '029' [O]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [48328f4]  '030' [O]
2021-05-26 10:24:01.416 [DEBUG][4]   Filter [4a8202c]  'NPVR TS Mon'
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [9bc46c]  'Input' [I]  Connected to [48213cc]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [9a79f4]  'Output' [O]  Connected to [e0d1bc]
2021-05-26 10:24:01.416 [DEBUG][4]   Filter [4826a6c]  'Capture'
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [4826dfc]  'MPEG2 Transport' [I]  Connected to [e0c2dc]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [48213cc]  'MPEG2 Transport' [O]  Connected to [9bc46c]
2021-05-26 10:24:01.416 [DEBUG][4]   Filter [e0bd64]  'Tuner'
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [e0c61c]  'Input0' [I]  Connected to [e04abc]
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [e0c2dc]  'MPEG2 Transport' [O]  Connected to [4826dfc]
2021-05-26 10:24:01.416 [DEBUG][4]   Filter [e049e4]  'Network Provider'
2021-05-26 10:24:01.416 [DEBUG][4]       Pin [e04abc]  'Antenna Out' [O]  Connected to [e0c61c]
2021-05-26 10:24:01.417 [DEBUG][4] Starting graph...
2021-05-26 10:24:01.420 [DEBUG][4] Calling LockChannel()
2021-05-26 10:24:01.431 [DEBUG][4] locked=0, present=0, strength=0, quality=0  (took 16ms to check)
2021-05-26 10:24:01.433 [DEBUG][4] DigitalRecorderDVBT::Tune@1
2021-05-26 10:24:01.433 [DEBUG][4] DigitalRecorderDVBT::Tune@2
2021-05-26 10:24:01.433 [DEBUG][4] DigitalRecorderDVBT::Tune@3
2021-05-26 10:24:01.433 [DEBUG][4] DigitalRecorderDVBT::Tune@4
2021-05-26 10:24:01.445 [DEBUG][4] DigitalRecorderDVBT::Tune@5
2021-05-26 10:24:12.684 [DEBUG][4] DigitalRecorderDVBT::Tune@post
2021-05-26 10:24:12.883 [DEBUG][4] Calling LockChannel()
2021-05-26 10:24:12.895 [DEBUG][4] locked=0, present=0, strength=0, quality=0  (took 0ms to check)
2021-05-26 10:24:12.896 [DEBUG][4] StartStream()@exit handle=1
2021-05-26 10:24:12.896 [DEBUG][4] StartStream succeded. Handle: 1
2021-05-26 10:32:00.171 [INFO][4] Got GET request: /stream/stop?handle=1
2021-05-26 10:32:00.189 [DEBUG][4] About to request async graph stop
2021-05-26 10:32:00.191 [DEBUG][6] Graph stopping... (async)
2021-05-26 10:32:00.195 [DEBUG][6] Graph reports state 'Stopped'
2021-05-26 10:32:00.195 [DEBUG][6] Graph stopped (async)
2021-05-26 10:32:00.196 [DEBUG][4] Async stop completed successfully
2021-05-26 10:32:00.199 [DEBUG][4] Removing filter  MPEG-2 Sections and Tables
2021-05-26 10:32:00.199 [DEBUG][4] Removing filter  BDA MPEG2 Transport Information Filter
2021-05-26 10:32:00.200 [DEBUG][4] Removing filter  MPEG-2 Demultiplexer
2021-05-26 10:32:00.201 [DEBUG][4] Removing filter  NPVR TS Mon
2021-05-26 10:32:00.205 [DEBUG][4] Removing filter  Capture
2021-05-26 10:32:00.206 [DEBUG][4] Removing filter  Tuner
2021-05-26 10:32:00.207 [DEBUG][4] Removing filter  Network Provider
I do not expect you to debug 3rd party software logs but I would appreciate if you could tell me how to debug the tuner during this issue & provide the information you require.
Info on setup:
Win10x64 with current driver (tbs6209_windows_driver_v1.0.0.7.zip)
Input signal DVB-T
Test record channel Frequencies:
578000 khz
586000 khz
Thanks in advance.
thatfellow
Re: TBS 6209 Octa-Tuner - Record 2+ simultaniously
Postby steven » Sun May 30, 2021 7:13 am
Hi Sir
One tuner one frequency , for
578000 khz
586000 khz
please do not use the same tuner , as 6209 have 8 tuners you can use
578 as first tuner , 586 as second tuner before record check every tuner whether can be locked .
Return to TV Signal Cable Connection and Mode Selection
