Tuner failure or UNICABLE problem?
Postby uuzi » Thu Jan 22, 2015 11:02 pm
I'm having weird problems with my card, since the beginning.
the second tuner just does not seem to work, it times out while tuning to any channel (see syslog beneath).
Strangely i can watch 2 channels on the same transponder simultaneously, but as soon as they are on different transponders the tuner times out.
additionally this error appears in syslog when vdr initializes the frontends:
tbs6981fe - Current Delivery System and Mode are unknown
Does this have something to do with my SCR/UNICABLE setup or is the tuner defective? the SCR/UNICABLE configuration of vdr is OK since it worked on my last Dual-Tuner Card.
whole syslog here:
http://paste.ubuntu.com/9820401/
whole dmesg output:
http://paste.ubuntu.com/9820406/
/etc/vdr/scr.conf:
http://paste.ubuntu.com/9820442/
/etc/vdr/diseqc.conf:
http://paste.ubuntu.com/9820439/
Please let me know if you guys need any additional info or logfiles.
uuzi
Re: Tuner failure or UNICABLE problem?
Postby smile » Thu Jan 29, 2015 10:38 am
Hi uuzi
"Strangely i can watch 2 channels on the same transponder simultaneously, but as soon as they are on different transponders the tuner times out" Are you use a signal cable,using spliter ,divided into two Singal cables respectively connected to the two tuner?
can you let me see a picture that show your UNICABLE's wiring?
Best Wishes
smile
