Problems with driver building (Debian Squeeze)
Postby noxx » Fri Mar 21, 2014 2:04 pm
i try to install and build the driver according the README in the tbs-linux-drivers_v140210.zip
the output (dmesg | grep frontend) after make and install and reboot was empty.
what i doing wrong? is there a easier way to install the driver? im new in linux.....
root@openmediavault:~/tbs# cd linux-tbs-drivers
root@openmediavault:~/tbs/linux-tbs-drivers# ./v4l/tbs-x86_64.sh
root@openmediavault:~/tbs/linux-tbs-drivers# make && make install
make -C /root/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/tbs/linux-tbs-drivers/v4l'
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for `default'.
Kernel build directory is /lib/modules/2.6.32-5-amd64/build
make -C /lib/modules/2.6.32-5-amd64/build SUBDIRS=/root/tbs/linux-tbs-drivers/v4l  modules
make[2]: Entering directory `/usr/src/linux-headers-2.6.32-5-amd64'
  Building modules, stage 2.
  MODPOST 0 modules
make[2]: Leaving directory `/usr/src/linux-headers-2.6.32-5-amd64'
./scripts/rmmod.pl check
found 0 modules
make[1]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l'
make -C /root/tbs/linux-tbs-drivers/v4l install
Removing obsolete files from /lib/modules/2.6.32-5-amd64/kernel/drivers/media/IR/keymaps:
Removing obsolete files from /lib/modules/2.6.32-5-amd64/kernel/drivers/media/video:
Removing obsolete files from /lib/modules/2.6.32-5-amd64/kernel/drivers/media/dvb/cinergyT2:
Removing obsolete files from /lib/modules/2.6.32-5-amd64/kernel/drivers/media/common:
Removing obsolete files from /lib/modules/2.6.32-5-amd64/kernel/drivers/media/dvb/frontends:
Removing obsolete files from /lib/modules/2.6.32-5-amd64/kernel/drivers/media/IR:
Installing kernel modules under /lib/modules/2.6.32-5-amd64/kernel/drivers/media/:
/sbin/depmod -a 2.6.32-5-amd64
make -C firmware install
Installing firmwares at /lib/firmware: vicam/firmware.fw dabusb/firmware.fw dabusb/bitstream.bin ttusb-budget/dspbootcode.bin cpia2/stv0672_vp4.bin av7110/bootcode.bin
before i make the driver i install
apt-get install module-assistant
apt-get install linux-headers-2.6.32-5-amd64
noxx
