Warnings during compilation
Postby Electuur » Sat Jun 15, 2013 10:36 pm
When I try to build the TBS6961 driver on Ubuntu 12.04 64 bit, I get the following warnings:
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs8921ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs8921ctrl.o.
Is this normal and can I ignore them or is there an error which has to be corrected?
Thanks, Electuur
jvl@M4A89-PC:~$ sudo su
[sudo] password for jvl:
root@M4A89-PC:/home/jvl# cd ~
root@M4A89-PC:~# cd tbs
root@M4A89-PC:~/tbs# ls
astra_scan-s2.conf         README_TBS6981   v4l-cx23885-avcore-01.fw
astra_szap-s2.conf         scan-s2.tar.bz2
linux-tbs-drivers.tar.bz2  szap-s2.tar.bz2
root@M4A89-PC:~/tbs# tar xjvf linux-tbs-drivers.tar.bz2
linux-tbs-drivers/
linux-tbs-drivers/README
linux-tbs-drivers/README.patches
linux-tbs-drivers/INSTALL
linux-tbs-drivers/COPYING
linux-tbs-drivers/Makefile
linux-tbs-drivers/linux/
linux-tbs-drivers/linux/firmware/
linux-tbs-drivers/v4l/scripts/usbvision.pl
linux-tbs-drivers/v4l/scripts/cx23885.pl
linux-tbs-drivers/v4l/tbsdvbcfe_driver.o.x86
linux-tbs-drivers/v4l/tbs6923fe_driver.o.x86
root@M4A89-PC:~/tbs# cd linux-tbs-drivers
root@M4A89-PC:~/tbs/linux-tbs-drivers# ./v4l/tbs-x86_64.sh
root@M4A89-PC:~/tbs/linux-tbs-drivers# make
make -C /root/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/tbs/linux-tbs-drivers/v4l'
No version yet, using 3.2.0-48-generic
make[1]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.2.0
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.2.0-48-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
  CC  ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.2.0-48-generic/build
make -C /lib/modules/3.2.0-48-generic/build SUBDIRS=/root/tbs/linux-tbs-drivers/v4l  modules
make[2]: Entering directory `/usr/src/linux-headers-3.2.0-48-generic'
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au0828-core.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au0828-i2c.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au0828-cards.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au0828-dvb.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au0828-video.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au0828-vbi.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au8522_dig.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au8522_decoder.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/ddbridge.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/firedtv.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/snd-bt87x.o
  Building modules, stage 2.
  MODPOST 516 modules
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5680ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5680ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5880ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5880ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5925ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5925ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbsdvbcctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbsdvbcctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5922ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5922ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5921ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5921ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbsctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbsctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5280fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5280fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5680fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5680fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5880fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5880fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5921fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5921fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5922fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5922fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5925fe_ctrl_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5925fe_ctrl_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs62x0fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs62x0fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6618fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6618fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6680fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6680fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6921fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6921fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6922fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6922fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6923fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6923fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6925ctrl_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6925ctrl_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6926_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6926_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6926ctrl_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6926ctrl_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6928fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6928fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6928se_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6928se_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6980fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6980fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6981fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6981fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6982fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6982fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6984fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6984fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6985fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6985fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6991fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6991fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs6992_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs6992_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs8921fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs8921fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs8922fe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs8922fe_driver.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbsdvbcfe_driver.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbsdvbcfe_driver.o
  CC      /root/tbs/linux-tbs-drivers/v4l/adp1653.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/adp1653.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/adv7170.mod.o
Electuur
Re: Warnings during compilation
Postby updatelee » Sun Jun 16, 2013 3:56 am
Ignore them. It's only because the modules are pre compiled.
