Install TBS6981 Mageia 2 x86_64
Postby ikhor » Mon Sep 24, 2012 3:25 pm
Hello
I'm on Mageia 2 x86_64, when I install the driver for the card TBS6981, there is no error message pandent installation, but when I restart the pc to check there is no driver installed .
Can you help me.
I have only this message
found 512 modules
make[1] : on quitte le répertoire « /home/laurent/Pilotes/tbs-linux-drivers_v120827/linux-tbs-drivers/v4l »
make -C /home/laurent/Pilotes/tbs-linux-drivers_v120827/linux-tbs-drivers/v4l install
make[1] : on entre dans le répertoire « /home/laurent/Pilotes/tbs-linux-drivers_v120827/linux-tbs-drivers/v4l »
\nRemoving obsolete files from /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/IR/keymaps:
\nRemoving obsolete files from /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/video:
\nRemoving obsolete files from /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/dvb/cinergyT2:
\nRemoving obsolete files from /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/common:
\nRemoving obsolete files from /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/dvb/frontends:
\nRemoving obsolete files from /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/IR:
Installing kernel modules under /lib/modules/3.3.8-desktop-2.mga2/kernel/drivers/media/:
        video/gspca/m5602/: gspca_m5602.ko
Kernel
[root@localhost laurent]# uname -a
Linux localhost.localdomain 3.3.8-desktop-2.mga2 #1 SMP Mon Jul 30 21:35:06 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Installation
# ./v4l/tbs-x86_64.sh
# make TARGET=x86_64-elf && make install
Verification
[laurent@localhost ~]# dmesg | grep cx23885
thank you
ikhor
Re: Install TBS6981 Mageia 2 x86_64
Postby SergioDanielG » Tue Sep 25, 2012 2:25 am
Hi ikhor.
Can you post dmesg log?
Best regards.
SergioDanielG
