tbs6981 - status information - how-to
Postby infiltrator » Thu Apr 12, 2012 7:58 am
I just wanted to know if it's possible to monitor certain metrics regarding the adapters. I would like to monitor numerous info and possibly graph them with rrdtool. Stats I'm hoping to display are:
Per adaptor:
In Use - yes/no
If in use what frequencies they are currently set to (ie typical metrics for channel lock)
SnR - monitor 'quality of signal'
I would like this to be non-intrusive as the adapters in my system might be in use by tvheadend recording a channel, etc.
Is this possible?
Thanks in advance.
infy
infiltrator
Re: tbs6981 - status information - how-to
Postby SergioDanielG » Thu Apr 12, 2012 10:39 am
I think that's posible and no than dificult because to do that is necesary read only access.
Maybe not all that you want, but basically, it's posible...
Best regards
SergioDanielG
