How to install TBS6981 on Linux Ubuntu 11.04 ?
Postby steven » Wed Jul 13, 2011 4:59 pm
Hi,all
You know that our TBS digital TV tuner cards/boxes have very good up to date Linux driver support, Although we provide read me doc in the Linux driver package, still many people could have question about how to install TBS6981 on Linux Ubuntu. Here is a simple 'how to' for you – follows these step-by-step guide you should be able to install up to 10 TBS6981 Dual Tuner cards in one PC easily.
Required:
TBS6981:it fully support linux ubuntu 11.04.
Install Environment: Linux Ubuntu 11.04(Kernel 2.6.38-8)
Installation steps:
1. Ensure that you have installed following packages:
* Kernel Sources
* gcc
* rar
* tar
* gzip
2. Download the latest driver from: http://www.tbsdtv.com/english/Download.html
3. Create an empty folder of TBS6981
mkdir TBS6981
4. Change path to the new directory
cd TBS6981
5. Unrar the driver
unrar e /path/to/driver/linux-s2api-tbs6981-#_#######.rar
where ##### means the version of the driver.
6. Unzip the base driver
tar xjvf linux-s2api-tbs6981_1.tar.bz2
7. Change directory to the driver path
cd linux-s2api-tbs6981_1/v4l
8. Based in your OS architecture do one of these:
On x86 (32 bit):
ln -s tbs6981ctrl.o.x86 tbs6981ctrl.o
ln -s tbs6981fe_driver.o.x86 tbs6981fe_driver.o
On x86_64/AMD64 (64 bit):
ln -s tbs6981ctrl.o.x86_64 tbs6981ctrl.o
ln -s tbs6981fe_driver.o.x86_64 tbs6981fe_driver.o
9. To use more than 4 cards edit following files:
On dvbdev.h file, change DVB_MAX_ADAPTERS to 16
On config-compat.h file, change CONFIG_DVB_MAX_ADAPTERS to 64
10. Compile the driver and install it
cd ..; make; make install
11. Install the firmware
cd /path/to/driver/
cp v4l-cx23885-######.fw /lib/firmware
Where ###### is defined as a brand and version
12. Reboot to load the driver reboot
13. After reboot you must have installed up to 2 * CardNumber adapters in /dev/dvb ls /dev/dvb
This article is contributed by Peter Mitrell.
Re: How to install TBS6981 on Linux Ubuntu 11.04 ?
Postby sami8519 » Fri Jul 15, 2011 8:25 pm
I don't perform this step yet the driver works just fine after reboot:
cd /path/to/driver/
Does this step really have a benefit, like for example, TBS driver won't need reinstall after kernel upgrades?
Regards,
Sami
sami8519
