kernel 2.6.38-8-generic
Postby mich111 » Thu Apr 28, 2011 7:13 am
Hi All, Just wondering if drivers are being written or are avaiable for testing with the 2.6.38-8-generic kernel, which is running in Ubuntu 11.04
Regards Mich
mich111
Re: kernel 2.6.38-8-generic
Postby smv1210 » Fri Apr 29, 2011 5:17 am
https://shop.tbsdtv.com/forum/viewtopic.php?f=3&t=114
Just forget about that, and ... select some other DVB card's vendor, if you like Linux so much...
smv1210
Postby mich111 » Fri Apr 29, 2011 7:36 am
Thanks mate.
I was using Win7 but the big problem was if you selected either input whilst the other was being used the used input would drop out. It didn't make any difference which drivers I used.
But in Linux the input selection worked ok.
Like in the other thread I don't understand why they can't free up the drivers. What a waste of money buying this card .
Mich
mich111
Postby stevellion » Sun May 15, 2011 5:36 am
Don't give up : Try this https://shop.tbsdtv.com/forum/viewtopic.php?f=22&t=420
Works for me, but was a bit of a struggle to start with :P
stevellion
