Signal/decoding problems
Postby mforest » Mon Dec 05, 2011 4:20 pm
I have 2 dvb cards, one TBS8920 and one TBS6981. The 8920 is rock solid. Whatever I tune to, it works wonderful. The 6981 can also tune anything, BUT, I keep getting huge amount if blocks/"crap" on the screen. Ever know and then I have perfect sound and picture and then it starts messing up again. MythTV is telling me "Serious error detected in Video Ouput". I have tried a large number of kernels and TBS versions. I have a splitter to split the signal to the "3" cards (2 in one card as the 6981 is dual). I have tried to remove the splitter and I still have the same issue.
Below is the dmesg output from the current kernel for muthbuntu 10.04.
$ dmesg |grep -i TBS
[ 19.761924] cx88[0]: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72,autodetected], frontend(s): 1
[ 19.802668] CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=33,autodetected]
[ 21.330039] Registered IR keymap rc-tbs-nec
[ 21.330126] input: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:08.0/0000:01:05.2/rc/rc0/input6
[ 21.330159] rc0: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:08.0/0000:01:05.2/rc/rc0
[ 21.443261] cx88[0]/2: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72]
[ 21.787128] TurboSight TBS 6981 Frontend 0 Attaching...
[ 22.103411] tbsfe: `1,1' invalid for parameter `pne'
[ 22.164475] DVB: Unable to find symbol tbsfe_attach()
[ 22.164481] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 22.191358] TurboSight TBS698x Dual DVB-S2 card port0 MAC=00:22:ab:f0:0a:6e
[ 22.191403] TurboSight TBS 6981 Frontend 1 Attaching...
[ 22.364230] tbsfe: `1,1' invalid for parameter `pne'
[ 22.434110] DVB: Unable to find symbol tbsfe_attach()
[ 22.434110] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 22.461082] TurboSight TBS698x Dual DVB-S2 card port1 MAC=00:22:ab:f0:0a:6f
[ 22.461117] Registered IR keymap rc-tbs-nec
[ 22.461393] input: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:14.0/0000:05:00.0/rc/rc1/input8
[ 22.464127] rc1: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:14.0/0000:05:00.0/rc/rc1
[ 40.679109] TurboSight TBS 6981 Frontend:
[ 40.679109] tbs6981fe - software version is 1.95.2.5
[ 40.679111] TurboSight TBS 6981 Frontend:
[ 40.679111] tbs6981fe - Successfully Initialized
When I'm running dvbtune, I'm getting the following.
$ dvbtune -f 1706000 -s 22500 -p h -m -c 2
Using DVB card "TurboSight TBS 6981 DVBS/S2 frontend"
tuning DVB-S to L-Band:0, Pol:H Srate=22500000, 22kHz=off
ERROR setting tone
: Invalid argument
polling....
Getting frontend event
FE_STATUS:
polling....
FE_STATUS: FE_HAS_SIGNAL FE_HAS_LOCK FE_HAS_CARRIER FE_HAS_VITERBI FE_HAS_SYNC
Bit error rate: 0
Signal strength: 48918
SNR: 23592
Signal=48919, Verror=0, SNR=50680dB, BlockErrors=0, (S|L|C|V|SY|)
Signal=48918, Verror=0, SNR=58981dB, BlockErrors=0, (S|L|C|V|SY|)
Signal=48918, Verror=0, SNR=59418dB, BlockErrors=0, (S|L|C|V|SY|)
Signal=48919, Verror=0, SNR=59418dB, BlockErrors=0, (S|L|C|V|SY|)
Signal=48919, Verror=0, SNR=59855dB, BlockErrors=0, (S|L|C|V|SY|)
Mythtv is reporting a rock solid / stable statistics as "Signal 74%, S/N 4.8dB, BE 0, (TL) Lock".
Happy to upload a few seconds of recording it that helps.
Have tried with /etc/modprobe.d/tbs6981fe.conf
options tbsfe pne=1,1
#options tbsfe pne=0,0
pne=0,0 make it totally unwatchable.
Any suggestions?
mforest
