6981 firmware not responding on centos8
Postby veehexx » Sat Jan 04, 2020 1:30 am
i'm in the process of upgrading my home server from centos7 with an elrepo 5.4.6 kernel and working 6981 card. I've used 4.x kernels in the past without issue on centos7 too.
when i upgrade to centos8 (stream release), which ships with a 4.18.0 kernel, i see the card present in 'dmesg | grep dvb', so i drop the .fw firmware file from the latest tbs linux driver pack (dated 2017) into /lib/firmware and i get repeated 'firmware not responding' in dmesg.
the card has been rock solid on centos7 and fine if i boot back into '7 so I'm confident there's something at software level than hardware.
anything i can do to fix, or is it time to look at replacing the hardware since it is starting to date now? Hope not as i want to stick with TBS but also want a DVB-S2 IP tuner.
veehexx
Re: 6981 firmware not responding on centos8
Postby steven » Mon Jan 06, 2020 10:14 am
Hi Sir
Please have a try reinstall with this pacakge :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2019-11-01.tar.bz2
#tar jxvf media_build-2019-11-01.tar.bz2
#cd media_build
#./install.sh
#reboot
kind Regards
