6981's power cable
6981's power cable
Postby cocoa117 » Thu Oct 20, 2011 9:19 pm
does anyone know if it is necessary to attach 6981's power cable to the power supply unit in order for it work? The power cable comes with the box, and the card seems running fine with power cable connected. But I just wonder if it is necessary at all.
thanx
cocoa117
Re: 6981's power cable
Postby warumnix » Fri Oct 21, 2011 9:21 am
Hello Cocoa117,
this thread may help you understand about the power cable
http://www.tbsdtv.com/forum/viewtopic.php?f=21&t=144
cheers,
warumnix
warumnix
Postby veehexx » Mon Oct 31, 2011 7:40 pm
i've also found out it's the same as a standard 6pin PCI-E connector as per any newer PSU.
ie: it's the same connector as all graphics cards that use the 6pin power connector.
veehexx
