DiSEqC problems
DiSEqC problems
Postby lawrence » Fri Sep 02, 2011 1:01 am
I have a universal LNB that is switched from lo-band to hi-band by sending a 22kHz tone. If I use szap to tune to a hi-band transponder then all is well. However, if I tune to a lo-band transponder then I get no lock. Scoping the signal on the coax shows the correct 13/18V but also a 0.5V p-p ~20kHz noise burst repeated every ~200uS. This appears to be confusing the LNB.
I played with the szap source and found that if I remove the call to ioctl(fd, FE_DISEQC_SEND_MASTER_CMD) then the noise burst goes away and lo-band transponders lock. To make the fix work for all apps I disabled the diseqc handler in the cx23885 driver with this patch:
diff -purN linux-tbs-drivers.orig/linux/drivers/media//video/cx23885/cx23885-dvb.c linux-tbs-drivers/linux/drivers/media//video/cx23885/cx23885-dvb.c
--- linux-tbs-drivers.orig/linux/drivers/media//video/cx23885/cx23885-dvb.c   2011-07-17 21:43:42.000000000 +0200
+++ linux-tbs-drivers/linux/drivers/media//video/cx23885/cx23885-dvb.c   2011-09-01 13:33:08.000000000 +0200
@@ -908,6 +908,12 @@ static int dvb_register(struct cx23885_t
          dvb_attach(tbsfe_attach, fe0->dvb.frontend);
       break;
+      /* There's a bug in the DiSEqC code that causes noise similar
+       * to the 22kHz tone to be constantly emitted. This prevents
+       * a simple LNB from tuning to lo-band transponders so for now
+       * disable DiSEqC
+      fe0->dvb.frontend->ops.diseqc_send_master_cmd = 0;
       break;
    case CX23885_BOARD_TEVII_S470:
Is this a h/w fault with this card or is this a driver bug?
This is in the latest linux-tbs-drivers_110818 built for Ubuntu 11.04 (kernel 2.6.38-10-generic #46-Ubuntu).
lawrence
Re: DiSEqC problems
Postby deffcon » Fri Sep 16, 2011 9:14 pm
Can you tell me howto patch this ?
I suspect the same strange hi, low.
Maybe we can make together a good howto ?
Dave
deffcon
Re: DiSEqC problems
Postby lawrence » Tue Sep 20, 2011 12:47 am
The patch is to be applied to the TBS driver before it's built.. Save the patch to a file (say ~/diseqc.patch) then cd to the directory into which you extracted the TBS drivers (e.g.~/linux-tbs-drivers) and execute:
patch -p1 < ~/diseqc.patch
Then rebuild the drivers by running 'make && sudo make install'
NB I was advised by TBS that this problem may be a fault with my card so I returned it for exchange and am awaiting the new one.
lawrence
Re: DiSEqC problems
Postby deffcon » Tue Sep 20, 2011 5:33 pm
thnx for you're quick reply, do you think its worth to try ? Maybe someone form tbsdtv can answer this question, or maybe more extensive testing for drivers. Let me know if i can help. Thnx
Dave
deffcon
