Tbs 8510 pro -> kylone License ..After a restart
TBS8520 and TBS8510
Postby a343 » Sun Aug 25, 2019 9:43 pm
Problem -> TBS 8510pro
After a restart
If you report Normal as admin and pass kylone @ 1
But then comes
-> License <-
To enter one expresses it is also made one then one is thanked,
But you can not get on the surface and on server display
stands -> Server Configuring <-....
That happened when I did a search and I wanted that
Delete channels and tuner settings then I have rebooted and get the problem
No more way!.. :cry:
a343
Re: Tbs 8510 pro -> kylone License ..After a restart
Postby steven » Mon Aug 26, 2019 9:25 am
Please send email to our support@tbsdtv.com we will help you about this
Return to TBS Transcoding solution
