[ Moderator Control Panel ]
TBS6301 HDMI Video Capture Card with HDMI1.4 port, completely support full HD Video and Audio capture and playback. It provides HDMI input of highest quality, and meets the HDMI 1.4 standard, satisfies the 1080i resolutions and can capture the LPCM audio signals in HDMI, you can easily capture signals from different kinds of devices by TBS6301 HDMI Capture Card without limitation. For TBS6301 windows driver is BDA architecture compatible with DVBDream,DVBView,... ,Linux driver is V4l architecture compatible with dvblast,tvheadend,astra..
by Jenny » Sat Sep 30, 2017 3:25 pm
Dear All,
Good day! Hope everything goes well with you.
TBS6301 HDMI HD capture card works as DVB tuner system device with its built-in H264 encoder for HDCP supported HDMI input interface including resolution and bitrate options. So integration is very simple. 4K version can be a future proof model. Besides, it supports both Windows driver and Linux driver. Here comes review made by openATV Team on TBS6301 card :
https://www.opena.tv/empfehlungen/36495-neue-tbs6301-capture-karte-im-handel.html Any further question, pls feel free to contact us. Thanks!
Best Regards,
TBS Support Team
E-mail
support@tbsdtv.comTBS Technology
Jenny
Return to TBS6301 HDMI Capture Card
