Access to previous driver versions for Windows
Postby Benoire » Mon Jul 15, 2013 4:41 am
I've updated my Windows Server 2012 Essentials with 2 x 6981s to the latest drivers. Unfortunately this is given me some serious problems with MediaPortal and I'd like to roll back to the previous version for testing. I cannot find this older version on your site, are you able to direct me to a download link OR can you at least make them available under a link so others can roll back easier if required.
Thanks,
Chris
Benoire
Re: Access to previous driver versions for Windows
Postby steven » Tue Jul 23, 2013 6:35 pm
Hi Benoire
On our download page you can get the latest version:
Win7 ,XP,Vista:
http://www.tbsdtv.com/download/document ... .0.1.6.zip
Win8:
Just need to change the version number:
http://www.tbsdtv.com/download/document ... .0.1.5.zip
Then you can download the V2.0.1.5 driver.
