TBS 6981 with proliant dl380 g5
Postby bashar1aziz » Mon May 13, 2013 4:24 pm
I have purchased TBS 6981 and tried to install it in an Proliant DL 380 server with Windows 2008 Server R2, but unfortunately I had some problems, when I go to the Device Manger I can see the TBS card and it says: code 39 unable to load device driver, the driver is up to date( downloaded from TBS website).
Any help would be appreciated.
Regards,
Bashar
bashar1aziz
Re: TBS 6981 with proliant dl380 g5
Postby steven » Sat May 25, 2013 11:19 pm
Hi bashar1aziz
Are you sure that you are installed the right version driver,You can have
a try with manual install driver for your windows,just to check what's your
windows version x86 or x 64
Kind Regars
Postby crazycat » Sun May 26, 2013 2:10 am
Hi steven,
Windows 2008 Server R2 not have BDA-subsytem, so need install some Windows Server 2008 R2 BDA patches from download
Postby steven » Fri May 31, 2013 4:07 pm
crazycat Wrote:Hi steven,
:D Thanks crazycat answer, yea need to intall the BDA path first . :)
