How to use remote with DVBViewer and TBSViewer
Postby steven » Wed Apr 11, 2012 3:04 pm
Hi All
Lots of people do not know how to use remote with DVBViewer and TBSViewer with TBS6981.
Here is the guide will help you.
First- Make sure that you have installed the virtual VHID driver,like this:
Second:Open DVBViewer Settings->Options Dialog Click Input,Take Channel Minus button as example.
1.Click Channel Minus's shortcut key
2.Click Learn Button.
3.Then you can input the key with TBS Remote,Just Press TBS Remote's CHL- Button.
4.After assign the new key,Press Apply.
5.After this you have assign Channel Minus button with TBS Remote.
Option Dialog
See how easy it is. :D
And here is the TBS good config file for DVBViewer,In the Options Dialog Press the Show Configuration folder,
then it will show the Configuration folder,Place TBS.remote to Remotes folder.Press Load Button you will see
this file just choose it,Press Apply then you can use TBS remote with DVBViewer.
TBS_DVBViewerRemote.zip
TBS DVBViewer Remote Config File
(2.16 KiB) Downloaded 2306 times
Then About TBSViewer with TBS6981.
Second:Just Click mouse right key on OSD,Options->Remote You will seen
TBSViewer Option
Click Settings.Take Recorder for example.
1.Click Recorder...
2.Click Lear
3.Click Recorder button on TBS Remote.
Then you can use recorder button with TBS remote.the other keys are like this too. :D
Any problem about this,just send reply on this topic,we will answer your question as soon as possible.
