win mce 7 crashes on full transponder scan
Postby barnsta » Thu Jul 21, 2011 11:32 pm
Hello
I purchased this card having had great results with my previous 6920 card. I installed the card last night, with drivers from website, all worked ok, but when I did a full transponder scan in MCE it crashed and rebooted. I have tried with the power cable directly plugged into the card and without. I have also changed the pci-e slot but with no joy.
my system is:
Foxconn A88gmx mobo
4 gig Ram
AMD 255 AM3 socket
Radeon 5950hd (passive cooled)
I have spent hours on this, please help.....
Barny
barnsta
Re: win mce 7 crashes on full transponder scan
Postby Quequeg » Fri Jul 22, 2011 2:11 am
Win 7 32 or 64-bit? I use 64-bit and MCE does a full scan fine, so if you are also using 64-bit there must be something else going on - do the windows error logs give any clues?
Quequeg
Postby gr4z » Sat Jul 30, 2011 6:49 pm
Exactly the same here - full scan and bam, 7MCE crashes.
W7 32bit here. Any suggested fixes?
gr4z
Postby steven » Sun Jul 31, 2011 6:30 pm
Sorry for the problem you have met,do you have used the older driver,Your CD's ,is it ok?and we will give you an answer as soon as possible.
Postby gr4z » Mon Aug 01, 2011 5:37 pm
I fixed this by resetting MCE using the following command:
mcupdate.exe -MediaCenterRecoveryTask
Unfortunately I am now getting random freezes when playing TV or watching a recording. I will try using the extra power cable to provide more juice to the card.
gr4z
