About the latest HD Channels lost in UK
Postby steven » Fri Jun 10, 2011 9:50 am
Hi All
Latest we have received that some users can not receive BBC HD channels,and from our consumers report:
RingaDing Wrote:Last week the BBC changed to S2 but I am unable to get my reciever to find them from either WMC or TBSViewer.
My dish is OK as I also run a Freesat box from it on a dual lnb which is recieving them ok after a retune.
Please can you help.
Satellite: Astra 2D tp.50
Frequency: 10,847MHz (vertical polarity)
Modulation: DVB-S2, QPSK
Symbol Rate: 23.0
FEC: 8/9
and
aquagraphite Wrote:
rgo222 Wrote:Try the scan again, and try checking your channel list to see if the channels are there.
As if by magic all seems to work! Seem to be getting a bit of blocking during the broadcast but I cant as yet pin point what is the culprit.
aquagraphite Wrote:I'll give it a go a soon as possible - thanks again....
EDIT: interesting 2 new channels found... ITV1 HD and 6942 though....
new solve method thanks BryanD
BryanD Wrote:Here is the fix if you are using DVBViewer.
Search for and Edit the 0282.ini files and change the existing 10847 line to
10=10847,V,23000,89,5,|BSkyB, BBC HD
This includes the new parameters 23000, 89, and 5.
A rescan should now find the files.
This was suggested to me by a friend and it worked great.
So we get a conclusion that BBC HD channels is not stable now and it maybe on adjust the signal and transponder parameter,to get a good condition.
Our advice is to update the driver use the latest driver on our download page:
http://www.tbsdtv.com/english/Download.html
and wait for it to become stable.
And We will try our best to solve this problem,please do not be worry about it.
Re: About the latest HD Channels lost in UK
Postby aquagraphite » Sat Jun 11, 2011 5:35 am
Yes definitely a stability issue it would seem on their end - not the card or 7mc
aquagraphite
