Slow channel change
Slow channel change
Postby onelegend » Sun Nov 27, 2011 5:07 am
Hi there
I currently have 3 machines each with TBS6981 tuners.
Software, DVBLogic TVsource 4.0.1:
I'm having problems with channel change times - it takes about 11 seconds to lock in on the first channel, about 6-8 when changing channels there after.
I must say, I downloaded DVBViewer - I have more then acceptable channel change times with that software (about 0.5 seconds), however this doesn't integrate into Win 7 Media Center.
I believe media center will be accountable for some of the above delay, but looking into the logs of DVBLogic TVsource, the channel lock is taking 4 seconds minimum, reducing that will make a big difference!
Log text from TVSource (4 seconds):
2011-Nov-26 14:53:48: [I] SetTuner() 10847000, V, 23000000 Mod:1 LOF:9750000 22Khz:0
2011-Nov-26 14:53:52: [I] Status: Locked
2011-Nov-26 14:54:14: [I] SetTuner() 10847000, V, 23000000 Mod:1 LOF:9750000 22Khz:0
2011-Nov-26 14:54:18: [I] Status: Locked
This occurs on all 3 machines, different system specs for each.
I have tried the latest driver of course - 2.0.1.1
Hope you can help
Many Thanks
Ian
onelegend
