Can i use another remote control?
Postby ssenyer » Mon Dec 27, 2010 5:40 pm
i want to use my dreambox remote control with mediaportal. i tried winlirc to configure my remote but unfortunately winlirc cant recognize ir reciever (i guess) .
Is there any way to use this build in ir reciever with winlirc? Or some documantetion maybe can help me while searching for a solution in internet.
Here is my remote controller lirc config file and screenshot.
http://lirc.sourceforge.net/remotes/dream_multimedia/
ssenyer
Re: Can i use another remote control?
Postby cody » Tue Dec 28, 2010 4:44 am
do you know what kind of codes your dreambox remote control uses - NEC, RC5, RC6, etc?
Postby ssenyer » Tue Dec 28, 2010 4:46 pm
cody Wrote:do you know what kind of codes your dreambox remote control uses - NEC, RC5, RC6, etc?
i know that it support RC5, not support RC6...no idea about NEC or something else. Is built in reciever compatible with RC6? if yes , i ll buy logitech harmony 300 RC for controlling all devices on my living room.
ssenyer
Postby cody » Wed Jan 05, 2011 6:05 am
TBS 6981 driver is compatible with NEC codes.
Postby ssenyer » Mon Jan 10, 2011 7:31 pm
Thanks for reply,
i bought a RC6 reciever and everything working well now.
ssenyer
