4 tuners, quad LNB, different number of channels
Postby tdiboy » Sat Nov 20, 2010 1:27 am
Hi there,
I've just finished installing my new 6981 and 8920 cards and have noticed something strange in DVBLink TVSource. Each card (including the existing Tevii S660) pick up a different number of channels.
At the moment, I'm using the latest drivers for each card which are hanging off a Zinwell (Mk4 model number 13822) Quad LNB:
8920:1.0.5.6
6981:2.0.0.12
S660:5.1.3.0 (beta).
The S660 seems to pick up the most channels at 923, then its the 8920 at 914 and finally (and the strangest one), the 6981 with 868(A) and 844(B).
I'm using whats known in the UK as a Zone 2 dish (instead of a Zone 1 which is the usual type in use in England) which is larger than the standard UK ones (designed for fringe coverage areas like Scotland).
Can you shed some light on this please as it a little confusing that there should be so much difference between them (especially the 6981's twin ports).
Dave
tdiboy
Re: 4 tuners, quad LNB, different number of channels
Postby cody » Tue Nov 23, 2010 3:56 am
hi Dave,
i agree that's very strange result considering especially the fact that Astra 28.2E signal is very strong over UK. so, i can give you some ideas what you can check more, which will help to understand what's going on:
- try different application than DVBLink TVSource just to rule it out as source of the problem
- is the reception of transponders (channels) that one card can't receive stable with the other that can receive them? you can check easily that with DVBDream and observing "Analysis -> Pid Statistics -> Demultiplexer Statistics" for errors. if the signal is not stable you will see errors there.
- do you always get the same number of channels with the same no matter how many times you scan or the number is always different? my point again is that the dish could be not adjusted good enough and signal on some frequencies is not stable.
regards,
