NEW TBS 6209SE Cheated(solved)
Postby ColombianoTV » Wed Apr 13, 2022 1:17 pm
I just spent 339 usd plus the trip to Colombia to obtain the card fraud TBS6209se does not take a signal from the Mhz frequencies 479000000 upwards, nor with linux drivers nor does it take a signal with windows drivers in the same frequencies .. it only takes 473, 479 Mhz .. has no signal in 485, 491 Mhz TDT Colombia
w_scan -c CO
w_scan version 20170107 (compiled for DVB API 5.11)
using settings for COLOMBIA
DVB aerial
DVB-T2 CO
scan type TERRESTRIAL, channellist 13
output format vdr-2.0
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
/dev/dvb/adapter0/frontend0 -> TERRESTRIAL "Turbosight TBS 6209SE(Octa DVB-T/T2/C/C2/ISDB-T/C/A": very good :-))
Using TERRESTRIAL frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.11
frontend 'Turbosight TBS 6209SE(Octa DVB-T/T2/C/C2/ISDB-T/C/A' supports
DVB-T2
INVERSION_AUTO
QAM_AUTO
TRANSMISSION_MODE_AUTO
GUARD_INTERVAL_AUTO
HIERARCHY_AUTO not supported, trying HIERARCHY_NONE.
FEC_AUTO
BANDWIDTH_AUTO not supported, trying 6/7/8 MHz.
FREQ (174.00MHz ... 868.00MHz)
Scanning DVB-T2...
Scanning 6MHz frequencies...
473000: (time: 00:00.000) signal ok: QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P0 (0:0:0)
QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P0 (0:0:0) : updating transport_stream_id: -> (0:0:20)
QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P0 (0:0:20) : updating network_id -> (0:12290:20)
updating transponder:
(QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P0 (0:12290:20)) 0x0000
to (QAM_64 f = 473000 kHz I999B6C34D0T8G8Y0 (8362:12290:20)) 0x405A
new transponder: (QPSK f = 0 kHz I0B999C0D0T2G32Y0 (8362:12290:21)) 0x4000
479000: (time: 00:04.827) signal ok: QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P0 (0:0:0)
QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P0 (0:0:0) : updating transport_stream_id: -> (0:0:10)
QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P0 (0:0:10) : updating network_id -> (0:12289:10)
(QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P0 (0:12289:10)) 0x0000
to (QAM_16 f = 479000 kHz I999B6C34D0T8G8Y0 (12289:12289:10)) 0x405A
new transponder: (QPSK f = 0 kHz I999B6C12D0T2G4Y0 (12289:12289:11)) 0x405A
new transponder: (QPSK f = 0 kHz I0B999C0D0T2G32Y0 (12289:12289:1)) 0x4000
485000: (time: 00:06.063) ----> NO SIGNAL
491000: (time: 00:08.163) ----> NO SIGNAL
497000: (time: 00:10.267)
503000: (time: 00:12.371)
509000: (time: 00:14.475)
515000: (time: 00:16.535)
521000: (time: 00:18.579)
527000: (time: 00:20.623)
533000: (time: 00:22.667) ^C
ERROR: interrupted by SIGINT, dumping partial result...
(time: 00:23.983) dumping lists (0 services)
Done, scan time: 00:23.983
root@tdtserver:/home/luise/w_scan-master#
root@tdtserver:/home/luise/t2scan-master# t2scan -Y CO
t2scan -Y CO
t2scan version 20201027 (compiled for DVB API 5.11)
DVB aerial
DVB-T2 CO
output format vdr-2.1
output charset 'UTF-8', use -I <charset> to override
Using DVB API 5.11
DVB-T2
INVERSION_AUTO
QAM_AUTO
GUARD_INTERVAL_AUTO
FEC_AUTO
MULTISTREAM
Scanning DVB-T2...
473000 (CH14): (time: 00:00.559)
plp id -1: signal ok: QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P-1 (0:0:0)
QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P-1 (8362:12290:20) : scanning for services
service = CARACOL TV HD (CARACOL TELEVISION SA)
service = CARACOL HD 2 (CARACOL TELEVISION SA)
service = BLU Radio (CARACOL TELEVISION SA)
service = LA KALLE (CARACOL TELEVISION SA)
(time: 00:08.935)
plp id 0: signal ok: QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P0 (0:0:0)
same network already found on CH (PLP ID updated from -1 to 0)
(time: 00:16.751)
plp id 1: signal ok: QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P1 (0:0:0)
Info: no data from NIT(actual )after 17 seconds
QAM_AUTO f = 473000 kHz I999B6C999D999T999G999Y0P1 (0:0:21) : scanning for services
service = Caracol Movil (CARACOL TELEVISION SA)
479000 (CH15): (time: 00:37.027)
plp id -1: signal ok: QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P-1 (0:0:0)
QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P-1 (12289:12289:10) : scanning for services
service = RCN HD (RCNTV)
service = RCN HD 2 (RCN TELEVISION)
service = RCN LA RADIO (RCN TELEVISION)
service = LA FM RADIO (RCN TELEVISION)
service = RCN RADIO UNO (RCN TELEVISION)
service = LA MEGA (RCN)
(time: 00:43.459)
plp id 0: signal ok: QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P0 (0:0:0)
(time: 00:50.123)
plp id 1: signal ok: QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P1 (0:0:0)
QAM_AUTO f = 479000 kHz I999B6C999D999T999G999Y0P1 (12289:12289:11) : scanning for services
service = RCN MOVIL (RCNTV)
485000 (CH16): (time: 00:59.419) ----> NO SIGNAL
plp id -1: no signal
491000 (CH17): (time: 01:01.523) ----> NO SIGNAL
497000 (CH18): (time: 01:03.627)
503000 (CH19): (time: 01:05.731)
509000 (CH20): (time: 01:07.787)
515000 (CH21): (time: 01:09.831)
plp id -1: ^C
(time: 01:10.915) dumping lists (12 services)
CARACOL TV HD;CARACOL TELEVISION SA:473000:B6S1Y0P0:T:27500:1001=27:1002=eng@3;1003:0;1024:0:21:8362:20:0
CARACOL HD 2;CARACOL TELEVISION SA:473000:B6S1Y0P0:T:27500:1011=27:1012=spa@3:0;1025:0:22:8362:20:0
BLU Radio;CARACOL TELEVISION SA:473000:B6S1Y0P0:T:27500:0:1041=spa@3:0:0:24:8362:20:0
LA KALLE;CARACOL TELEVISION SA:473000:B6S1Y0P0:T:27500:1051=27:1052=spa@3:0:0:25:8362:20:0
Caracol Movil;CARACOL TELEVISION SA:473000:B6S1Y0P1:T:27500:1201=27:1202=eng@3:0:0:30:0:21:0
RCN HD;RCNTV:479000:B6S1Y0P0:T:27500:101=27:102=eng@3,103=eng@3:0;1024:0:2:12289:10:0
RCN HD 2;RCN TELEVISION:479000:B6S1Y0P0:T:27500:301=27:302=eng@3:0:0:3:12289:10:0
RCN LA RADIO;RCN TELEVISION:479000:B6S1Y0P0:T:27500:0:602=spa@4:0:0:5:12289:10:0
LA FM RADIO;RCN TELEVISION:479000:B6S1Y0P0:T:27500:0:402=spa@4:0:0:6:12289:10:0
RCN RADIO UNO;RCN TELEVISION:479000:B6S1Y0P0:T:27500:0:802=eng@3:0:0:7:12289:10:0
LA MEGA;RCN:479000:B6S1Y0P0:T:27500:0:803=spa@4:0:0:8:12289:10:0
RCN MOVIL;RCNTV:479000:B6S1Y0P1:T:27500:1101=27:1102=spa@3:0;1025:0:1:12289:11:0
Done, scan time: 01:10.915
I have TBS 6205 and found good in same Linux drivers and Windows Drivers
ColombianoTV
Re: NEW TBS 6209SE Cheated
Postby smile » Thu Apr 14, 2022 10:10 am
please check your signal cable if connect to the RF "IN", if your signal strength is too strong<-1dBm~-20dBm>, please try connect to "OUT".
and the signal cable do not connect any signal amplifier or spliter. the cards has sufficient signal sensitivity(-1dBm~-70dBm) for dvbt2 singal.
or Could you give us the SSH to check it? email to me Davin@tbsdtv.com or support@tbsdtv.com
Best Regards
smile
Postby ColombianoTV » Fri Apr 22, 2022 8:26 pm
I want to apologize to the TBS STAFF, the error was mine with the orientation of the DVB-T2 antenna, the TBS card is working 100% and without problems since then... :D
ColombianoTV
