TBS6290 with RaspberryPi Compute Module 4 IO Board
Postby 1bit » Sat Nov 20, 2021 10:58 pm
Has anyone tried running the TBS6290 card with RaspberryPi Compute Module 4 + IO Board?
The RaspberryPi Compute Module 4 IO Board has PCIe Gen 2 x1 socket
but not sure if power wise it would work.
Reading the "User guide" for the card
https://www.tbsiptv.com/download/tbs620 ... _guide.pdf
and it states:
Note: 6209 of the work must be tuned external power supply connected to the card
so how would one go about connecting/powering the card?
Thanx in advance.
1bit
Re: TBS6290 with RaspberryPi Compute Module 4 IO Board
Postby zhangchao » Mon Nov 22, 2021 10:04 am
hi ,
yes , 6209 of the work must be tuned external power supply connected to the card . but 6290 is generally not needed。
if you need to install driver in raspi , please add skype jack_2431.
best regards!
zhangchao
