"all tuners at the same time / tuners in sequence" comment
Postby SquareEyes » Mon Jun 15, 2020 3:46 pm
I posted this question in another thread but I think it might get lost and unanswered so have started a new thread:
I'm thinking about getting a TBS6209 for Windows but I noticed this comment in another thread which sounds unusual:
TheTroll Wrote:The card does not like if we open all tuners at the same time, FW loading of all tuners must be done in sequence.
1. What is meant by "done in sequence"? Does it only let me open tuners in sequence? Can I not use Tuner0 and Tuner7 independently without using other tuners in between?
2. What happens about opening all tuners at the same time? I can use all tuners in two quad cards, can I not use all tuners in octa card without any issues?
SquareEyes
Re: "all tuners at the same time / tuners in sequence" comme
Postby SquareEyes » Tue Jun 23, 2020 10:08 pm
@Steven Any info?
SquareEyes
Postby steven » Tue Jun 30, 2020 9:46 am
Hi SquareEyes
When you first open the PC if you using more than 1 x6209 such as 4x6209 , after system running up please wait about 1 minutes then start using the tuners
as every card need some time to init ,after init you can use all at the same time as you want
Postby SquareEyes » Tue Jun 30, 2020 8:58 pm
@steven - Thank you. No, hopefully I only need 1 x6209. Good to hear I can use all tuners.
Does it mean I can use any tuner and tuners do not need to be used in sequence?
For example if I use T0-T3 for SD and T4-T7 for HD I am able to use, for example T1 and T7 in my software and it will be fine?
I don't need to use tuners in sequence - T0 and T1?
SquareEyes
Postby steven » Wed Jul 01, 2020 9:35 am
Hi SquareEyes
Yea you do not need to care about the sequence.
Postby SquareEyes » Fri Jul 10, 2020 1:22 am
@steven Thank you.
SquareEyes
