Informations about recording with TBS 6209
Postby mourn » Mon Oct 14, 2019 9:25 pm
The card is octa tuner so with it can I record 8 different channels (from different frequencies; italian channels in my case) at the same time?
Does the card support windows 10?
mourn
Re: Informations about recording with TBS 6209
Postby steven » Tue Oct 15, 2019 3:48 pm
Hi Sir
yes it is 8 tuners you can receive 8 frequency at the same time not 8 channels usually one frequency have about 5 channels so you can receive more than 8 channels
and we have windows driver and application
any more question you can leave here .
Postby mourn » Tue Oct 15, 2019 7:02 pm
steven Wrote:Hi Sir
Thank you Steven for the answer.
So all of these channels can be recorded simultaneously?
What's the output file format?
mourn
Postby steven » Wed Oct 16, 2019 11:53 am
For the format is the orignal from DVB TS stream we do not process it , if the sources is H.264 then it is H.264. file format is ts format
