too much warning: TS discontinuity on pid xxx
Postby juanchito51 » Mon May 13, 2019 12:53 pm
maybe there is a fault in the tbs 6209 card TDT2; on a frequency with 100% signal it tunes very well, but on another, also with 100% signal there are too many "warning: TS discontinuity on pid xxx".
"warning: TS discontinuity on pid 1002 expected_cc 0 got 8 (H.222.0/13818-1 PES private data, sid 21)
warning: TS discontinuity on pid 1041 expected_cc 10 got 1 (11172-3 audio (MPEG-1), sid 24)
warning: TS discontinuity on pid 1003 expected_cc 9 got 7 (11172-3 audio (MPEG-1), sid 21)
warning: TS discontinuity on pid 1052 expected_cc 11 got 3 (11172-3 audio (MPEG-1), sid 25)
warning: TS discontinuity on pid 1012 expected_cc 4 got 11 (11172-3 audio (MPEG-1), sid 22)
debug: frontend has lost signal
debug: frontend has lost carrier
debug: frontend has lost FEC
debug: frontend has lost sync
debug: frontend has lost lock "
tests:
1. change the cable and shorten distance to 4 meters. same result ("warning: TS discontinuity on pid ...")
2. move the location of the antenna 20 km and tune it to other frequencies 100% signal . same result ("warning: TS discontinuity on pid ...")
On the TV in both locations it tunes perfectly on all channels, maybe there is a fault with this card, or if there is an option in dvblast to ignore these warnings?
Any comments or help will be appreciated.
juanchito51
Re: too much warning: TS discontinuity on pid xxx
Postby steven » Tue May 14, 2019 9:48 am
Do you have tested another frequency ? is it the same ? and please have a try change the PCI-E slot
you can share your dvblast scan parameters here.
