TBS 6209 card hangs when using tuner #4
Postby TheTroll » Fri Dec 01, 2017 5:05 am
I am using the latest git version of the open source drivers, on kernel 4.4 and 4.11.
I noticed that my card with hang (I get timeout on all tuners) when I try to use tuner number 4 )(/dev/dvb/adapter4).
Is it a faulty unit ? Any idea ?
TheTroll
Re: TBS 6209 card hangs when using tuner #4
Postby steven » Fri Dec 01, 2017 10:16 am
Hi TheTroll
When the problem happen can you send the whole dmesg log to our support@tbsdtv.com we will have a check with this
And do you have tried change the PCI-E slot ? and connect the extra power for 6209 ?
Postby TheTroll » Fri Dec 01, 2017 2:50 pm
Hi Steven,
thanks for getting back to me.
There is nothing in dmesg and yes, the power is plugged.
TheTroll
Postby TheTroll » Fri Dec 01, 2017 5:45 pm
I confirm it’s a faulty unit, it works fine with the other 6209 I bought.
TheTroll
Postby steven » Tue Dec 05, 2017 6:24 pm
Hi TheTroll
Thanks for your update , already send PM message please have a check
