Driver 1.0.1.4 and Change Mode Tool error
Postby fatal » Mon Nov 02, 2020 11:41 pm
Since I've updated the driver to 1.0.1.4 (Windows 10 20H2), Change Mode tool before starts shows the following error/warning message multiple times:
Change Mode Tool Warning / Error
It changes mode without problem, I've just wanted to inform you about this little bit annoying behavior. Maybe the change mode tool needs an update.
Also when I've updated the driver it set both tuners to "NO SET" mode, while MediaPortal showed DVB-S for both tuners (and they were in DVB-C before).
fatal
