PCI-e 1.0a compatibility + back cover question
Postby NewsFloat » Thu May 10, 2018 9:04 pm
Hello, just wanted to ask:
1. Does the compatibility problem mentioned here exist in the TBS6590, or is it solved?
2. Is some sort of back cover provided, to use when only one (or none) CI slot is being used? (to protect from dust etc.)
Thanks again
NewsFloat
Re: PCI-e 1.0a compatibility + back cover question
Postby steven » Thu May 17, 2018 4:25 pm
Hi NewsFloat
Thanks for your interest of our tuner card and for your questions :
1. 6590 using new PCI-e bridge have not the 1.0a comaptiable issue
2. Sorry that there is no cover when you only use one CI slot . but it is ok you do not need to worry too much
Any more question please feel free to ask us
