No HD Channels after standby - TBS 6980
Postby TBSBWL » Wed May 11, 2011 9:57 pm
Hello, I've just done a rebuild of my Windows 7 x64 box and I've got some issues which have cropped up.
Windows x64, SP1 + latest updates
TBS 6980 DVB-S dual tuner card. Driver version 2.0.0.18
Hauppauge Nova-T DVB-T dual tuner. Driver 4.3.27240.0
DVB Link 3.2.2
ATI 5770. Driver version 11.4
Core 2 Duo CPU @ 2.4GHz
4GB RAM
After standby, there are no DVB-S channels. I think it's only the HD channels as they are the ones which are DVB-S only. The other channels are replicated on the Happauge card so not sure 100% if SD channels are affected also.
I have to restart the ehRecevier service to get them back. Can you please assist?
Also, you seem to be having trouble with a few spammers on your forum! :)
TBSBWL
Re: No HD Channels after standby - TBS 6980
Postby steven » Thu May 12, 2011 10:52 am
Would mind to tell me your mainboard,and try to update your mainboard's BIOS,because after our test TBS6980 is ok after standby.
Postby TBSBWL » Fri May 13, 2011 11:29 pm
The MB is an Asus P5Q-Deluxe.
I am using BIOS version 2201, the latest is 2301, but only thing changed is a fan function.
I'm willing to update the BIOS if you want to rule it out.
thanks, Brian
http://support.asus.com/Download.aspx?SLanguage=en&m=P5Q+Deluxe&p=1&s=22
Is there any logging I can turn on and capture for you?
TBSBWL
Postby steven » Sat May 14, 2011 3:22 pm
Would mind try to update your BIOS,and you can see this
https://shop.tbsdtv.com/forum/viewtopic.php?f=2&t=2#p699
long time ago ,some user tell this bug too,and it can be solved by some method.
