Windows System Event 54 followed by a 45
Postby SlimJimE17 » Thu Feb 10, 2011 8:00 pm
Hi all,
I use WinXP with drivers 2.0.14, I have seen the following error sometimes in m windows event logs: -
Event Type: Warning
Event Source: tbs6980
Event Category: None
Event ID: 54
Date: 08/02/2011
Time: 14:17:34
User: N/A
Computer: HTPC
Description:
The description for Event ID ( 54 ) in Source ( tbs6980 ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: .
Data:
0000: 00 00 00 00 01 00 58 00 ......X.
0008: 00 00 00 00 36 00 04 80 ....6..€
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
This is then followed by this: -
Event Type: Information
Event Source: Application Popup
Event ID: 45
Date: 08/02/2011
Time: 14:17:34
User: N/A
Computer: HTPC
Description:
A device driver is leaking locked I/O pages causing system degradation. The system has automatically enabled tracking code in order to try and catch the culprit.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 00 00 01 00 d4 00 ......Ô.
0008: 00 00 00 00 2d 00 00 40 ....-..@
0010: 13 00 00 00 2d 00 00 40 ....-..@
Has anybody else seen these events?
SlimJimE17
Re: Windows System Event 54 followed by a 45
Postby steven » Fri Feb 11, 2011 5:01 pm
Would mind to tell me ,when this problem caused,like change channel,move motor and so on!
which soft you are using when it occur?
You can also contact with us, support@turbosight.com
Postby cody » Mon Feb 14, 2011 6:30 am
@SlimJimE17
is that causing any real problem - i mean the one that you can actually experience? because i think it could be just Windows warning message is wrong, because 6980 card is doing heavily I/O operations to transfer the TS data from the satellite, which rate is very high - at least few tens of megabits per second.
