TBS-5990 with 2 CI and 1 Sat Cable
Postby tako035 » Fri Nov 11, 2016 4:09 am
I have TBS-5990 with 2 CI modules installed but I have only one cable so I plugged it into SAT-A at the moment. Can I use these two CI Modules with only SAT-A.
Best Regards,
TaKo
tako035
Re: TBS-5990 with 2 CI and 1 Sat Cable
Postby highkick05 » Mon Dec 05, 2016 10:45 pm
tako035 Wrote:Hello,
Best Regards,
TaKo
nfi but sounds like u need to read maybe some oscam doc .. probably would do it u mightthink
highkick05
Postby steven » Thu Dec 15, 2016 5:20 pm
The CAM is paired to the tuner can not used by other tuners : )
Postby highkick05 » Thu Dec 15, 2016 6:12 pm
steven Wrote:Hi
thanks for clarifying that man, but you'd think you could assign tuner B to use the CI (A) .. I think it's @ /dev/tbsci0 (not sure of device name tvheadend has version where there is a device in DVB inputs for the CI's) from within oscam config's
or some such bs. probly can be done in linux/oscam
highkick05
