Driver v 1.0.1.3 doesn't work on Windows 10
Postby Scrambler » Thu May 03, 2018 3:29 pm
For some reason with each driver update for my TBS6528 I'm facing the issues.
I found out that you guys have the new drivers version released https://www.tbsiptv.com/download/tbs652 ... .0.1.3.zip
I downloaded it and tried to update the driver on my system (Windows 10 x64, config: https://valid.x86.fr/1g4x6q).
The system said that I have a better driver installed (1.0.1.2). Maybe it is because the new 1.0.1.3 drivers are improperly compiled and their release date is earlier than the date of the previous version (1.0.1.2).
Drivers' dates
I installed 1.0.1.3 in multiple ways - via TBS_6528_dvb_driver_setup.exe, via Windows device manager driver update, via .ini file installation from explorer - in all cases the result was the same - none of my DVB apps can detect DVB-C signal with 1.0.1.3 drivers.
I tried ProgDVB 7.23.07 and DVBDream v2934, provided by TBS https://www.tbsiptv.com/download/common ... _v2934.zip
As soon as I revert back to 1.0.1.2 version of drivers - everything starts to work fine.
So I have two questions:
1. Is there a way to make 1.0.1.3 working on Windows 10?
2. Is it possible to find previous versions of drivers on TBS site just in case someone will have to re-install the system and doesn't have a backup copy of the drivers, and the new version of the drivers simply doesn't work at all?
Thank you.
Scrambler
Re: Driver v 1.0.1.3 doesn't work on Windows 10
Postby Scrambler » Sun May 20, 2018 12:34 pm
Will anyone respond?
@steven ?
Scrambler
Postby steven » Fri May 25, 2018 9:37 am
Hi Scrambler
If you want to use DVB-C please use the mode change tools to change the mode :
https://www.tbsiptv.com/download/tbs652 ... .0.0.2.zip
Postby Scrambler » Fri Jun 29, 2018 2:23 pm
steven Wrote:Hi Scrambler
Hello Steven,
Thanks. That's what I did in the first place - made sure that the card is in DVB-C mode. It was in DVB-C, but none of the programs could work with the new driver. As soon as I reverted back to the previous version of the drivers - it worked fine. But that, older, version of a driver is not available through the TBS website anymore. So if I'll have to re-install the Windows there is a chance that I will end up with the non-usable card.
Scrambler
Postby steven » Mon Jul 02, 2018 6:12 pm
Please have a try with this new driver :
tbs6528_bata_V1004_Win10.zip
6528 win10 driver
(1.54 MiB) Downloaded 1064 times
Postby Scrambler » Fri Aug 03, 2018 7:05 pm
steven Wrote:Hi
Hello Steven,
I apologize for delay.
tbs6528_bata_V1004_Win10 works just fine right after installation.
Thank you!
Scrambler
Return to TBS6528 Multi Standard Dual Tuner CI PCI-e Card
