Few questions on the single connector
Postby NewsFloat » Wed Apr 11, 2018 4:05 am
Hello everyone, recently found out about your very interesting TV cards. A few questions on the TBS6528:
1. I'm a bit confused with the single input connector. The card supports both DVB-T and DVB-S but there's only one input. Is there some sort of 2-to-1 adapter that can allow simultaneous connection of both antenna cables, or the only way is to manually switch cables? The USB multi-standard products seem to use the same tuners but have two separate inputs.
2. I'm also not sure of what the ChangeMode Tool's function is. Does the user have to manually use it every time a channel is switched between DVB-T and DVB-S?
Thank you.
NewsFloat
Re: Few questions on the single connector
Postby smile » Wed Apr 11, 2018 3:30 pm
1) the card using a switch component to change the recevice dvbt and dvbs signal circuit.
2) the change mode tool use for change the demod status. if you want recevice the dvbt/t2 signal, need make demod on the dvbt/t2 mode.
Best Regards
smile
Return to TBS6528 Multi Standard Dual Tuner CI PCI-e Card
