How many inputs do i need?
Postby SPiKeGoD » Fri Mar 08, 2024 8:26 am
TBS6522H
In TBS6909 i have an only cable for working with the 8 adapters.
Is it possible to share an input between different input like in the tbs6909? O, do i have to connect 2 cables of the same signal for DVB-S and 2 cables of the same signal for DVB-T?
Thanks you very much
SPiKeGoD
Re: How many inputs do i need?
Postby smile » Fri Mar 08, 2024 2:56 pm
Hi sir
You need 4 signal input, because one signal input corresponds to a tuner+demodulation chip. there are 4 chip on the board.
this is different with the 6909.
Best Regards
smile
Postby SPiKeGoD » Fri Mar 08, 2024 4:47 pm
smile Wrote:Hi sir
Best Regards
Ok, thanks
SPiKeGoD
