TBS 6522 and minisatip
Postby marinefish17 » Fri Dec 11, 2020 9:33 pm
I try to connect minisatip to the tuner but unfortunately minisatip don't see dvbs2. It can see only dvbc and dvbt. I use adapter 0 for Satellite and adapter 1 for cable.
I use tbs6522 with tvheadend and work properly but I need to use this card for 3 users in same time(not all the time) so therefore I try to use minisatip in between.
It's there any settings to run minisatip,tvh and tbs6522?
Thanks!
marinefish17
Re: TBS 6522 and minisatip
Postby steven » Mon Dec 14, 2020 3:17 pm
Hi Sir
TBS6522 only have two tuners , for the 3 users if they are watching 3x different transponders then 1xTBS6522 can not support .
thanks
