TBS6522 Windows 10 v1903 - Bluescreen, v1909 Code 28 Error
Postby Andi1984 » Mon Feb 03, 2020 12:37 am
I've been using a TBS6522 tuner card under Windows 10 x64 for a while (using the drivers: "TBS6522 Windows 10 Driver V1.0.1.2"). It worked fine on all Windows 10 versions up to and including v1809.
But it does not work on any of the two newest versions: v1903 and v1909.
- When trying to update to Windows 10 v1903, I always get a Bluescreen in tbs6522.sys during the update. There's no way to install the update, after a few times the same Bluescreen, it reverts back to the previous version (v1809).
- When trying to update to Windows 10 v1909, I got one Bluescreen in tbs6522.sys during the update, and after a reboot, the update was at least installed. But the card does not work and in device manager I get code 28 Error (No compatible drivers).
Are there any newer Windows 10 drivers than V1.0.1.2 for this card available?
Best regards,
Andi
Andi1984
Re: TBS6522 Windows 10 v1903 - Bluescreen, v1909 Code 28 Err
Postby steven » Tue Feb 04, 2020 9:43 am
hi Sir
Please use the older version first ,let us check at our side ,it is our vacation now when we start work will check this ASAP
Postby Andi1984 » Thu Mar 26, 2020 12:45 am
Is there any update on this issue?
Best regards,
Andi
Andi1984
Postby smile » Thu Mar 26, 2020 4:51 pm
sorry for delay reply, please try this test version drvres.
http://www.tbsiptv.com/download/tbs6522/tbs6522_release_V1015_beta.zip
Best Regards
smile
Postby Andi1984 » Thu Apr 16, 2020 3:08 am
smile Wrote:...
Many thanks, it works fine with these drivers. :)
Best regards,
Andi
Andi1984
