Problem with 6903X (Diseq switch not working)
Postby enb141 » Sat Jun 08, 2019 7:40 am
Hi, I got a problem with my 6903X card, Diseq switch doesn't works with either TBS Blindscan 3.0.2.2 nor CrazyScan, I'm using driver version 2001_1108_win10.
I also have problems with DVBDream, when I try to add channels after a channel scan it freezes DVBDream.
Another problem that I have is that the card is not able to tune anymore, so I have to disable and enable from Device Manager in order to make it to work again.
None of this happens with my 6922SE on the same PC
enb141
Re: Problem with 6903X (Diseq switch not working)
Postby steven » Sat Jun 08, 2019 11:45 am
Thanks for your feedback ? can you send one email to our support@tbsdtv.com and tell us which diseqc you are using ? if you can setup the remote
it will be great ,you can send the remote information too teamview ,anydesk both are ok
Postby enb141 » Sat Jun 08, 2019 12:20 pm
Thanks for the response, I just sent the email, the DiSEqC switch looks like this one
DiSEqC Switch
enb141
Postby enb141 » Mon Jun 10, 2019 6:05 pm
After doing some tests and thanks to steven, now DiSEqC works, with the updated files for TSReader and after clicking on "set DiSEqC" before duing a scan, now CrazyScan switches to my DiSEqC port.
Thanks for your help steven.
enb141
