DVB-S2 and DVB-T2 at the same time...
Postby wie69 » Sat Dec 01, 2018 11:10 am
hi ..
before i purchase this card TBS6522..
i need more information..
i plan to use on my TVHEADEND server... so i need to know if this card can use DVB-S2 and DVB-T2 together at the same client request on my TVHeadend Server...
regards
Wie
wie69
Re: DVB-S2 and DVB-T2 at the same time...
Postby steven » Tue Dec 04, 2018 9:30 am
For 6522 it is dual tuner you can using with tvheadend one tuner for DVB-S2 the other for DVB-T2 no problem works very well
do not need to worry about this
Postby wie69 » Sat Dec 08, 2018 10:34 am
hello steven,,
thanks for your reply,...
i need more information,, on the card have 2 ports DVB-S/S2 and 2 ports DVB-T/T2..
so i can use only 1 port DVB-S/S2 and 1 port DVB-T/T2 ?? for 2 clients at the same time
or
i can use 2 ports DVB-S/S2 and 2 ports DVB-T/T2 ?? for 4 clients at the same time
regards
Wie
wie69
Postby steven » Mon Dec 10, 2018 9:54 am
It have 4 input but you can only use 2 tuners at the same time , if you need more tuners you can try TBS6904 or TBS6205 which both have 4 tuners : )
kind Regards
Postby wie69 » Wed Dec 19, 2018 10:27 am
hi steven
so you mean, 2 input port on DVB-T/T2 side is connected so can only use 1 input..
also same with DVB-S/S2 side ???
regard
wie
wie69
Postby steven » Thu Dec 20, 2018 3:10 pm
If you put two cable to the DVB-T/T2 side then you can using 2x DVB-T signal
the combina will liek this
2xDVB-T/T2/C
or
2xDVB-S/S2
or
1xDVB-T/T2/C and 1x DVB-S/S2
clear now ? : )
Postby marinefish17 » Mon Jan 27, 2020 3:07 am
wie69 - connect the sat cable on dvb-s 0 and ter cable on dvb-c 0. At tvheadend setup the network on adapter 0.
marinefish17
Postby steven » Thu Jan 30, 2020 10:27 am
Hi Sir
if both signal connect to port 0 then you are able using the first tuner
so best
connect the sat cable on dvb-s 0 and ter cable on dvb-c 1
