[ Moderator Control Panel ]
by hasecomp » Tue Nov 28, 2017 6:46 pm
Just received the TBS6522 card I ordered, but I dare not install it.
There is a separate power supply connection on the card. Is the PCIe power supply not sufficient? Do I really have to use this separate power supply connection or is it superfluous?
The installation part of the user manual makes no mention of it.
I'm confused.
Kind regards,
Andre Hasekamp.
hasecomp
by steven » Wed Nov 29, 2017 10:51 am
Normallly use you do not need to connect the extra power for your card , just in case if you connect big motor the power from PCI-E slot not enough then you will need the extra power .
by hasecomp » Wed Nov 29, 2017 7:41 pm
Thank you.
Andre Hasekamp.
hasecomp
